I have not found any threads about exporting images from the manage links dialogue box. I want to repath 212 of them from one of my users local C drives to the server.
Are there any nodes that might help with this? Even if it just exports them and does not repath them would be super helpful.
hi,
an example with Python
import sys
#import Revit API
clr.AddReference('RevitAPI')
#import transactionManager and DocumentManager (RevitServices is specific to Dynamo)
def get_imgLocal_path(img_type):
if img_type.RefersToExternalResourceReferences():
for dict_externalRef in img_type.GetExternalResourceReferences():
if dict_externalRef.Value.HasValidDisplayPath():
for dict_info in dict_externalRef.Value.GetReferenceInformation():
if dict_info.Key == "Path":
return dict_info.Value
all_images = FilteredElementCollector(doc).OfClass(DB.ImageInstance).ToElements()
all_imagesType = [doc.GetElement(xId) for xId in set([e.GetTypeId() for e in all_images])]
OUT = all_imagesType, [get_imgLocal_path(img_type) for img_type in all_imagesType]
@curtisridenour
Did you resolve this ?
Bummer…
I can get the linked images etc but can’t work the writetofile part.
I have managed to repath all the links which is better than nothing
