how can im get list with values withaut connections:
Is this what you seek?
almost
Not totally sure I get the point. Did you see this page?
http://dynamoprimer.com/en/07_Code-Block/7-3_shorthand.html
I figure out that you are in fact looking for this:
no !))))
im exactly need get lists from elements out of PythonScript ))
its really trouble i think
You can paste and format your code here with this button:
Here is how:
@til.shviger Paste the code as @Yna_Db requested. You need to paste the code if you want others to help you.
@til.shviger Is this your code?
# Import RevitAPI
clr.AddReference("RevitAPI")
# библиотека динамо для работы с ревитом
# Использование библиотеки DSCoreNodes (основные ноды расположенные на вкладке библиотеки слева в разделе Core)
clr.AddReference("DSCoreNodes") # DSCoreNodes.dll лежит здесь C:\Program Files\Dynamo\Dynamo Core\1.3
import DSCore
clr.ImportExtensions(DSCore)
from DSCore import *
import itertools
#Назначьте вывод переменной OUT.
list_ps=[]
list_fs=[]
list_elbow=[]
list_tee=[]
list_z=[]
#filter pipes
list_ps=[i for i in IN[0] if i.GetCategory.Name=="Трубы"]
#filter pipes fittings
list_fs=[i for i in IN[0] if i.GetCategory.Name=="Соединительные детали трубопроводов"]
#get intersectioon fittings with pipes
for k in list_fs:
for j in list_ps:
if k.BoundingBox.Intersects(j.BoundingBox)==True:
sublist= [k, j]
list_z.append(sublist)
lst=sorted(list_z, key=lambda x: x[0] )
#Sort pipes from fittings
ps = dict()
for x in lst:
p = x[0]
if p in ps:
ps[p].append(x[1])
ps[p] = [x[1]]
result = sorted([v for k,v in ps.items()], key = lambda x: x[0])
# elbow and tee lists
#for i in result:
# if i.Count==2:
# list_elbow.append(i)
# else:
# list_tee.append(i)
OUT = result
I will die if you not understand me
We are doing our best
im so happy…
I have never seen anything like that and I am not that advanced with Python to be able to find any quick solution. But I am sure that someone else will have a clearer idee on it…
Yna_Db,
thanks for your time)
in out of python may be list of elements or values it is not important
important its transmit data between code blocks or python without connectors (wires) which looks like spiderweb when is exist many code blocks
