Exploded DWG fill region types, Smart ideas?
Drafting views aren’t BIM… The model can change and the drafting view stays the same.
If you have a CAD detail you want, put it into a Revit family and use that as a detail overlaid on the actual Revit model.
Then if the model changes you can see your detail needs adjustment.
Understand what your saying but a lot of landscape detailing isn’t relevant to the model. However some of the typical guideline details can adjust depending on the job. It’s more finding the best middle ground to get the job done.
Did it! :partying_face: Can change the 86 duplicated earth patterns to the correct 1 now. Along with other patterns too. Placed them to check it was finding similar patterns. Assuming the next part is easy :melting_face:
