When I try to use an element that created from FilterRule.ByRuleType in Python Node, I got that error. Element has that type: Revit.Filter.FilterRule. How can I convert it to API type?
Thank you very much!
# Phython-Standard- und DesignScript-Bibliotheken laden
import sys
import System
from System.Collections import *
clr.AddReference("System.Core")
clr.ImportExtensions(System.Linq)
clr.AddReference("RevitAPI","RevitServices")
filterRule = UnwrapElement(IN[0])
if not hasattr(filterRule,"__iter__"):
filterRule = [filterRule]
tempL = List[FilterRule]()
for i in filterRule:
tempL.Add(i)
#ElementParameterFilter(tempL)
OUT = dir(tempL)
The basic question: How can I convert RevitNodes object to API object?
Hello
in this case it will be necessary to use reflection, the accessibility of the property ‘InternalFilterRule’ is limited
Merci @c.poupin!
I tried everything and it did not help. I thought, there may be a workaround to solve that. It seems I have to invest time into ZeroTouch development.
try this
import sys
import System
#import Revit API
clr.AddReference('RevitAPI')
#import net library
clr.AddReference("System.Reflection")
from System.Reflection import BindingFlags
e = IN[0]
invokeObj = clr.GetClrType(e.GetType()).InvokeMember('InternalFilterRule', BindingFlags.InvokeMethod | BindingFlags.GetProperty | BindingFlags.Instance | BindingFlags.Public | BindingFlags.NonPublic, None, e, None)
elemFilter = DB.ElementParameterFilter(invokeObj)
OUT = invokeObj.GetType(), elemFilter
OMG! That is amazing! Thank a million time!
I saw that Invoke function on GitHub but I can’t C# or .Net very well. I knew, you could solve it!
