Excel.WriteToFile failing when using multiple values
So i have a excel file wich i want to create multiple formulas in dynamo to populate its cells.
I have a length and a width value of rooms in excel and i want to calculate that using dynamo.
I know how to do that in excel, i want to urnderstand how dynamo does this calculus.
Here is a picture of the script and the result in excel after it is runned.
I wanted that the perimeter and column valumns would be inserted in a vertical way in excel… But it is been strangely added as a line.
Does anybody has any clue to solve this?
Thank you!
PS: I’m attaching both the excel and dynamo files.
TabelaDeAreas.xlsx (8.4 KB)
Excel.dyn (19.8 KB)
Your list structure and starting cells are backwards. Data needs to be by row (one sublist = one row of data) and your cells would all start at Column E (4) and Row 1 (0). You don’t have multiple input locations if you have everything formatted correctly.
Perfect!
Thank you!
