Errors when deleting objects created by Dynamo
I’m seeing a reoccurring issue when I try to delete objects in Civil 3D that were created by Dynamo. As shown in the image, I tried to delete these profile objects, but empty profiles are left behind. The only way I can remove them is by auditing the drawing. However, Civil 3D crashes with a fatal error when I try to close the drawing after that. See FatalError.txt (2.9 KB)
This only seems to happen if the dyn file that created the objects is open in Dynamo. Even if the dyn has not been run for the current session.
Is this a known issue? Any remedies?
PhantomObjects
Hi @keith.sowinski
Please submit issue here:
Done.
