Error opening corrupted file;
Hi all,
I have seen many posts about the same problem, but i don’t know even it stated that the version 1.2.2 is the up-to-date version for me. I am using the revit 2018 and i don’t know the problem. Thank you for any help!
Likely you are opening a Dynamo 2.x file in an outdated 1.x version of Dynamo.
Try upgrading to 2.0.3 (the latest version for Revit 2018 and 2019) from here: https://dynamobuilds.com/
Best to also confirm your Revit is up to date (2018.3.3) while you’re at it, as you may be missing a security update that is preventing the update notification.
Hi @jacob.small,
I have solved the problem with the upgrading! Thak you for your help!
