Hi Everyone!!!
I try get List LevelName and List GridName from project.
Why sometime get that error, sometime not show.
# -*- coding: UTF-8 -*-
clr.AddReference('System.Windows.Forms')
clr.AddReference('System.Drawing')
import System.Drawing
import System.Windows.Forms
from System.Drawing import *
from System.Windows.Forms import *
from System import IntPtr
doc = __revit__.ActiveUIDocument.Document
uidoc = __revit__.ActiveUIDocument
AllGrid = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Grids).WhereElementIsNotElementType().ToElements()
GridName = []
for i in AllGrid:
GridName.append(i.Name)
setGridName = set(GridName)
AllLevel= FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Levels).WhereElementIsNotElementType().ToElements()
LevelName = []
level_elevation = []
for i in AllLevel:
LevelName.append(i.Name)
level_elevation.append((i.Elevation)*304.8)
dic_level = {}
for x,y in zip(LevelName,level_elevation):
dic_level[x] = y
items = AllGrid
curves = []
def Curve(dimension):
curve = []
if dimension.DimensionShape == DimensionShape.Linear:
direction = dimension.Curve.Direction
if dimension.NumberOfSegments == 0:
start = dimension.Origin.Subtract(direction.Multiply(dimension.Value/2))
end = dimension.Origin.Subtract(direction.Multiply(-dimension.Value/2))
curve = Line.CreateBound(start,end).ToProtoType()
for segment in dimension.Segments:
start = segment.Origin.Subtract(direction.Multiply(segment.Value/2))
end = segment.Origin.Subtract(direction.Multiply(-segment.Value/2))
curve.append(Line.CreateBound(start,end).ToProtoType())
return curve
def getCurve(section):
#Get the section view from the Section Marker
if ElementId(BuiltInCategory.OST_Viewers) == section.Category.Id :
viewSection = doc.GetElement(ElementId(section.Id.IntegerValue + 1))
elif isinstance(section,Autodesk.Revit.DB.ViewSection):
viewSection=section
shape = viewSection.GetCropRegionShapeManager().GetCropShape()
#Last line of the rectangle
l = [s for s in shape[0]][3]
#Replace the Z value by 0
curve = Line.CreateBound(XYZ(l.GetEndPoint(0).X,l.GetEndPoint(0).Y,0),XYZ(l.GetEndPoint(1).X,l.GetEndPoint(1).Y,0)).ToProtoType()
return curve
try:
for item in items:
doc = item.Document
view = doc.ActiveView
#Railing
# if hasattr(item, "GetPath"):
# curves.append([railpath.ToProtoType() for railpath in item.GetPath()])
#Revision Cloud
if hasattr(item, "GetSketchCurves"):
curves.append([sk.ToProtoType() for sk in item.GetSketchCurves()])
elif hasattr(item, "LocationCurve"):
curves.append(item.LocationCurve.ToProtoType())
elif hasattr(item, "FullCurve"):
curves.append(item.FullCurve.ToProtoType())
elif hasattr(item, "ValueOverride"):
curves.append(Curve(item))
elif hasattr(item, "Curve"):
curves.append(item.Curve.ToProtoType())
elif hasattr(item, "GeometryCurve"):
curves.append(item.GeometryCurve.ToProtoType())
elif hasattr(item, "GetEndpoint"):
curves.append(item.ToProtoType())
elif isinstance(item,Autodesk.Revit.DB.MultiSegmentGrid):
curves.append([doc.GetElement(i).Curve.ToProtoType() for i in item.GetGridIds()])
# elif version > 2019 and isinstance(item,Autodesk.Revit.DB.Analysis.PathOfTravel):
# curves.append([i.ToProtoType() for i in item.GetCurves()])
# elif ElementId(BuiltInCategory.OST_StructuralColumns) == item.Category.Id and not item.IsSlantedColumn :
# curves.append(colCurve(item))
elif hasattr(item, "GetCurvesInView"):
for crv in item.GetCurvesInView(DatumExtentType.ViewSpecific,view):
curves.append(crv.ToProtoType())
#Get ViewSection or section marker curve
elif ElementId(BuiltInCategory.OST_Viewers) == item.Category.Id or isinstance(item,Autodesk.Revit.DB.ViewSection):
curves.append(getCurve(item))
elif hasattr(item, "Location"):
loc = item.Location
if isinstance(loc,Autodesk.Revit.DB.LocationCurve):
curves.append(loc.Curve.ToProtoType())
curves.append(None)
else: curves.append(None)
except Exception as e:
MessageBox.Show(str(e))
