"Error: EOF expected" in Code Block node on Dynamo 1.3
If I use a file path string in Code Block node on Dynamo 1.3, I receive “Error: EOF expected”.
When I use the following graph in Dynamo 1.2, there is not any problem.
However, I open same graph in Dynamo 1.3, I receive the following error.
If I type file path (ex. "C:\Temp…) in Code Block node, this issue is happened.
The work around is I type “\” (ex. "C:\\Temp…).
Is this specification change in Dynamo 1.3?
I had to put in
to get a backslash in 1.2.
(Also in AutoLISP strings since the 1980s.)
@truevis
yes i also use “\\” and “/” as a habit…legacy from LISP…
Hi truevis, 4bimferdie.espiritu,
Thank you very much for comments.
OK. I should use “\” in code block.
