Hello all,
I am probably doing something wrong or == does not work on elements. I should be able to find a way around this but would like to know whats going on. I tried changing the inputs but same result. See image below
Hello all,
Use Element.Id node and then use β==β node. Your currently connecting elements to it.
The βEqualsβ node might work on elements.
Thanks for the reply and the recommendation. Your way is much simpler than what I ended up doing. It defiantly has to do with something in the background coding of dynamo but seems strange to me that it cannot recognize the same element. Grabbing the elements id is super easy though.
Steven
