Endpoint elevation label
Is there a node in Civil 3D dynamo to retrieve the value of the endpoint elevation label?
Hi
Can you attached example drawing
Sorry, cannot attach for business use.
Make an example.
Or at least explain what’s endpoint value?
Is it the endpoint for profile or featureline?
@buf_fa, unfortunately the code which you’re asking for is also for the same business use. Please re-read this post before continuing to engage here.
