Elevation in wall hosted families
Is there a way to read and map or only read the elevation parameter that controls the height for wall hosted families?
Capture
Thanks,
Yes - Can you show us your graph? :slight_smile:
there is no Elevation parameter that i can read it 02
Sorry if you had already worked this out… you were reading a Type but the parameter is an Instance…
Hope that helps,
Mark
