I managed to copy the elements from linked model but they are in the wrong location. I’m a beginner at python but I think there is something to do with transforming the elements to match the current model coordinates? But I’m not sure which code to use or where to put it.
from RevitServices.Persistence import *
from RevitServices.Transactions import *
clr.AddReference("RevitAPI")
import System
def tolist(obj1):
if hasattr(obj1,"__iter__"): return obj1
else: return [obj1]
links = UnwrapElement(tolist(IN[0]))
cats = UnwrapElement(tolist(IN[1]))
for link in links:
linkDoc = link.GetLinkDocument()
catId = List[ElementId](c.Id for c in cats)
filter = ElementMulticategoryFilter(catId)
fec = FilteredElementCollector(linkDoc).WhereElementIsNotElementType().WherePasses(filter)
elem = list(fec)
ids = List[ElementId]([i.Id for i in elem])
copied_elements = ElementTransformUtils.CopyElements(linkDoc,ids,doc,Transform.Identity,CopyPasteOptions())
elements = [doc.GetElement(i) for i in copied_elements]
OUT = elements
Try to use GetTotalTransform() instead of Transform.Identity.
Since they are in a link, they have a transform in the link, and related to the actual document.
To understand better, use RevitLookUp (you can found on jeremy tammik blog) and compare transforms
Thanks @FabioDeAgostini, I did just that and it worked. It looks pretty messy but it is a working script.
import System
def tolist(obj1):
else: return [obj1]
for link in links:
t = link.GetTotalTransform()
elem = list(fec)
# transaction start
#copy elements from link-doc to current-doc
copied_elements = ElementTransformUtils.CopyElements(linkDoc,ids,doc,t,CopyPasteOptions())
# transaction done
# get elements from ids
# output
OUT = elements
