Element ID - but not the ID?
OK… this is done in C# … BUT it’s still a Revit question :smile:
I have a model in place item (rectangle extrusion).
If I take the individual lines I get these IDs
If I take the extrusion inside the MIP family I get this ID:
This is the ID of the Model in Place within Revit:
So what on earth ID is my script logging??
        private void OnDocumentChanged(object sender, Autodesk.Revit.DB.Events.DocumentChangedEventArgs e)
            Document doc = e.GetDocument();
            // Check added elements for in-place families
            foreach (ElementId id in e.GetAddedElementIds())
                Element element = doc.GetElement(id);
                if (element is Family family && family.IsInPlace)
                    // Exclude in-place masses
                    if (family.FamilyCategory.Id.Value != (int)BuiltInCategory.OST_Mass)
                        // Log the usage and include the ID number
                        LogModelInPlaceUsage(doc, id);
Ah… It wasn’t the instance… Which is confusing because what else is model in place? :person_shrugging:
    // Check added elements for in-place families (instances)
        if (element is FamilyInstance familyInstance)
            // Check for in-place family
            if (familyInstance.Symbol.Family.IsInPlace)
                if (familyInstance.Symbol.Family.FamilyCategory.Id.Value != (int)BuiltInCategory.OST_Mass)
                    // Log usage
