The Element.GetParameterValueByName node does not return the correct value with “reference level” and a pipe, a sheath a cable path.
The MEP elements are in a linked file. The node works with the accessories.
hi @Alain_Hamel this parameter is Read only :
Hello
Thank you for your reply.
I’m on REVIT 2016, I installed Revit Lookup, but I can not find the window Snoop parameters.
There are several versions?
Question: Will this solution only work on the current model, or will it be definitive in REVIT?
OK, thanks
