When DynaShape output the space results, the spaces are grouped into deparments (hence you will notice that the output spaces are organized as a 2-level list). I decided to do it this way because it make it easier to post-process the spaces bubbles (e.g. coloring them by department)
You can re-sort them manually to get the original order, like you already did. It is actually not that efficient because it is not the computational bottleneck and is only done once whenever you pause the exeuction.
Thank you for your explanation, now I see the logic behind it. So to solve my problem, it is enough to keep spaces grouped into departments how it is in the sample excel file. I do it and it works correctly!
Hi guys!
I’ve installed DynaShape package 2.6, Revit 2024. I am getting this warning message I have no clue what it is about. Does somebody knows what is the cause of this message? Thank you for your reply
