Hello everyone,
I’m hoping to get some assistance with a Dynamo script. I’m trying to place a family type into my Revit model at specific coordinates that I’ve pulled from an Excel file.
I’m using Dynamo 3.03 and Revit 2025 .
The script is running, but the last nodes are returning a null value and not placing any elements. I’ve no idea how to overcome this.
Here is a screenshot of my current graph: [Insert link to a screenshot here]
I’ve also uploaded my Dynamo script and a sample Excel file here if anyone wants to take a look: https://drive.google.com/file/d/1OcD4UjVfXRM5Reqm41VvcjhF-4q6toRP/view?usp=sharing
Any advice or guidance on what I’m doing wrong would be greatly appreciated. You can access the .dyn file from the link below:
Thank you so much in advance for your time!
bvs1982
September 10, 2025, 12:37pm
2
Screenshot and Excel file are missing?
What are you selecting in your Dynamo here ?
Also in your script there is nothing which points to an Excel? So i don’t understand this .
Also .
Node Name: Wall.ByCurveAndLocation
Original Node Name: Wall.ByCurveAndLocation
Package: WombatDynamo.Wall.Actions
Dynamo Version: 3.3.0.6316
Host: Dynamo Revit
Messages: Wall.ByCurveAndLocation expects argument type(s) (Autodesk.DesignScript.Geometry.Curve, double, Revit.Elements.Level, Revit.Elements.WallType, string, bool), but was called with (string, double, Revit.Elements.Level, Revit.Elements.WallType, string, bool). href=NonOverloadMethodResolutionError.html
State: Warning
EDIT
After bit of fiddling with your .dyn. i get (to) this.
Host: Dynamo Revit
Messages: Wall.ByCurveAndLocation operation failed.
Method not found: ‘Int32 Revit.Elements.Element.get_Id()’.
State: Warning
Hi all,
I’ve been using the graph below succesfully for Revit 23-models, but it stopped working in Revit 24. The Element.IntersectsElement-node returns the error ‘Int32’ method not found. I have no idea what this means. I was a great fan of this node and wouldn’t want to eliminate it in favor of the variant using bounding boxes.
Anyone knows what is going on and how to resolve it?
[Schermafbeelding 2025-04-30 100920]
[Schermafbeelding 2025-04-30 100954]
EDIT 2
This one works though . So my guess the issue is in the node(s) from the WombatDynamo package.
