Dynamo steel framing
I created a dynamo code to model an antenna’s frame. The modeling is correct in the dynamo view. But once I assign the frame families to the model, some frames don’t appear in the 3D Revit view. I’ve been searching and talking about it for several days without a solution. Can someone help me?
You will need to pass on the script/image of it, and plus how things should look compared to how revit is displaying them.
Plus also read the following for some guidance - How to get help on the Dynamo forums - FAQ - Dynamo
