Dynamo Script create with revit 2021 are not visible in revit 2020
If I create a script in dynamo and revit 2021 and then I will open the script in revit 2020 the script is not visible and dynamo crash.
In Revit 2020 I Use Dynamo core 2.3.1.11775 and dynamo Revit 2.3.1.11830
In Revit 2021 I have Dynamo core 2.6.1.8786 and dynamo Revit 2.6.1.8850
thank you very much
Hi @Mayo
Maybe a better fit for the dynamo github issue list: Sign in to GitHub · GitHub
in any case, it is a good habit to provide more background info or data: dynamo log, crash log, screen capture, the script itself eventually, the list of custom packages used in the script.
