I can’t find anything on my C drive either…
I wanted to see what there was as I want to give someone at work a basic Dyno intro.
Can I download these from somewhere?
can you see them inside dynamo under help menu and samples ?
Try here
And here
Generally samples should be saved to the following folder, though do change the version to the relevant version.
C:\ProgramData\Autodesk\RVT 2025\Dynamo\samples
Though there was/is a issue with some localised folders having less than the US folder.
My guess is that this is the issue for you Alien. The Revit team has an outstanding bug on the issue which should have been fixed in the most current builds, but if you’re in something old it might not have been picked up. What build are you in @Alien ?
Yep - that’s a year behind. Try 2026 and you should get results.
