I’m trying to filter out all elements from by active document in Dynamo python by parameter name id it exists in the elements.
Heres my Python code:
import sys
clr.AddReference('RevitAPI')
def get_parameter_value_by_name(find, element, parameterName):
if str(find) == element.LookupParameter(parameterName).AsString():
return element
find= IN[0]
# 'find' contains the value of parameters, based on this we need to filter out the elements
elem = FilteredElementCollector(doc).WhereElementIsNotElementType().ToElements()
#All element in document (or I say Model)
elements = []
# Place your code below this line
for i in find:
for j in elem:
try:
elements.append(get_parameter_value_by_name(i, j, "JB"))
except:
pass
continue
OUT = elements
Didn’t know a lot about Revit API, I think I’m writing something wrong didn’t figure out where and what ?
import sys
return element
find= IN[0]
elements = []
for i in elem:
try:
elements.append(get_parameter_value_by_name(find, i, "Comments"))
except:
pass
OUT = filter(None, elements)
I suppose haven’t asked my question properly or in a right way.
Earlier, with this script I already got the elements that having those values as an output. But in addition to that I also need the remaining elements as well , who has ‘JB’ parameters as in its properties , weather its contain bank value.
And I suppose I can just add one more blank item in my ‘find’ input list.
find= IN[0]+[" "]
#But its no good, all elements not appeared having 'JB' parameter
Hope this time, it will be clear. In your case, the same goes for ‘Comments’
Or I would say, I need to filter out the elements by parameter names (‘JB’) if exists not by its value.
