Dynamo package for doors/windows
Are there any Dynamo Packages built for specifically windows and doors? Using GetParameterValue doesn’t seem to be working some of the time.
Could you be more specific. May be a screenshot might help others to understand who is trying to help you.
Is it a ‘Type’ and ‘Instance’ parameter issue? Sometimes you need to feed in the Window Family Type into GetParameterValue node to get a ‘Type’ parameter value.
I guess yes this is the issue. The areas extracted are almost double of what they should be
Width * Height for approximate areas of rectangular windows?
You’re probably getting the solid area which includes all faces so would usually be about double the expected area of the opening.
@simon_murphy1 was right. It was Instance and Type issue. I was directly extracting Area from AllElementsinCategory. Getting the type and then extracting Height and Width solved the problem.
