Good evening I need to numbering and list the wall layers on a legend (or schedule) in revit without unjoin the wall in multiple components.
I got the list in dynamo and I’m trying to write this list in a multiple line parameter in the wall. Can anyone help me.
Do you want all those parameters combined into one parameter? If so you can use String from Array.
P.S. You should get Dynamo V1.3, which has a list level function built into all the nodes.Then you won’t need to use List.Map.
I think you can finish it with String.Join and Element.SetParameterByBame
Thank you very much it work with string from Array and Element.SetParameterByName.
Please start a new topic for a new question.
