Hi all,
I was trying to set as Dynamo package path a folder located on BIM 360.
This is easy to do thanks to the Desktop Connector which creates a drive on your local pc.
However, it seems to not work properly and when I open Dynamo, the various packages don’t show up as usual (except for built-in ones).
Do you have any experience on that?
Did you try or do you know if there are any chances to set this path?
Thank you in advance for your collaboration,
Best regards
