Dynamo-How to Replace the Location Curve of a Curve-Based Column/Beam
Hi everyone,
I met a problem with updating curve-based column/beam geometry (ie, updating start/end points of the location curve) in Dynamo.
What I have now (Input) is:
  1. A list of curve-based structural columns (1500 columns). Since they are curve-based columns, I can use dynamo to show their current location curves (straight line segments with start/end points).
  2. New location curves (centerlines) for these columns, with new start/nd points coordinates known (Thus 1500 curves too).
What I need Dynamo to do is:
For each of the column in the list, abandon the current location curve, and replace to the new location curve.
A previous topic is similar with this question, but it is about point-based columns and it was solved by a python script node.
http://dynamobim.com/forums/topic/dynamo-to-relocate-placed-family-in-revit-file/
I tried to adapt the python code to this curve-based column problem, but have not worked out a correct code. Anyone who is familiar with Revit API/Python could give me a help? Or could this problem solved by existing Dynamo nodes?
Kind regards,
Tiger
Please post a Revit file with a couple of columns in it so we can test based on your dataset.
@Tiger please post a link to your files (dropbox, etc.)
Does this not work for your situation?
