Dynamo for rebar
[caption id="" align=“alignnone” width=“1600”]
I would like know if could doing a reinforced slab with DYNAMO. This slab is part to bridge, and these slope and curves. Can i giving it skew? I want to horizontal and vertical bars. It not inclined[/caption]
Hi alls.
Hey, Gerardo.
The picture of your script is too pixelated, and I don’t fully understand your question. Can you upload a better quality picture of your script and sepcify more what you need help with?
For help with rebar-modelling in Revit check out Dieter Vermeulens blog: revitbeyondbim.wordpress.com and Håvard Vasshaugs site: vasshaug.net. They have a lot of helpfull stuff that will help you in your design.
HI, PAL. THANKS FOR YOUR HELP. MY MAIN QUESTION IS: -HOW DO I GIVE IT ANOTHER ORIENTATION TO THE BARS?, BECAUSE NOW FOLLOW THE SIDES OF THE SLAB AND I WOULD LIKE THEM TO BE HORIZONTAL AND VERTICAL. AS IN THE IMAGE OF AUTOCAD
I’ve made a script that generates rebar normal and paralell to the “straight” edge faces. Feel free to re-use it and fit it to your needs. However, it needs some adjusting to cut the rebars at the edge faces. I put in some efforts towards this without any luck though, but you should consult the Curve.Trim nodes which should be able to fix this.
skewed slab
Hmm, doesn’t seem as the file is accepted as an attachment on the forum. Send me a DM and I will get it to you.
Please refrain from posting email addresses on the open forum - doing so increases the number of bots and spammers who try to get into the community.
Please message me with a link.
