Warning: Geometry.ImportFromSAT operation failed.
Could not load file or assembly ‘file:///D:\program setup\DynamoCoreRuntime2.11.1\LibG.ProtoInterface.dll’ or one of its dependencies. The system cannot find the file specified.
That’s the error I get while importing an SAT file into Dynamo.
Typically this is because none of the applications which provide Dynamo with a geometry engine are not installed.
Do you have Revit, Civil 3D, AutoCAD, or another core Autodesk product installed?
Yeah, I use Alias and Fusion 360. Is it in any way compatible with any of those two?
Install Dynamo for Alias and launch from there instead of in the sandbox environment.
