Greetings,
I am creating a curve path between points to which will be used to acquire perpendicular angle and publish it to polycurve profiles.
The issue I am having is that the line can be create as a Revit curve (with Dynamo) and it intersects each intended point along the path but I am unable to achieve the same results in Dynamo. Is there an obvious option other than Nurbs curve that I have missed? (I have tried converting the Revit curve by element to Dynamo but it still misses the points)
I appreciate any help on this one.
