Dynamo Civil Draw parts in Profile Views
Hello everyone, I would like to share this topic with the forum, to get some suggestions about it. I think it might be interesting for other Civil3D users. My problem is related to the need to project several pipe networks in the profile view. You must first specify the workflow used. I received the survey of the as-built pipe network via 3d polylines, now I have rebuilt the alignments, profiles and profile views, then I have rebuilt the as-built pipe networks and I like to draw the parts in profile view.
Thanks you all
Hello, do you have any script you are working on and need help?
@n.rapetti @Drbohlav
FYI I’ve included some nodes in the Camber package for this.
@zachri.jensen this is really cool, with this, one could theoretically add parts to profile view that are within a certain offset from the alignment correct?
Yep!
This looks very promising, thank you for posting. I am trying to get this working for my project but starting with a simple example. Right now, I am only getting the function to output a projection onto a single profile. Does this work with multiple profiles if they come from a list? Or is the function only meant to output one profile edit? If the former, how might I change my inputs to let dynamo know I want it to execute this function for every combination in the lists I am providing?
Hi @dforrestMJRCQ,
This is probably because of the list levels. See how the list of Profile Views is nested (lists within lists)? Either flatten the list of Profile Views using List.Flatten before plugging into Part.AddToProfileView or change the ‘profileView’ input on Part.AddToProfileView so that it applies to @L2.
After a part has been added to a profile view, either in the Camber package or elsewhere, is there a way to set it’s style?
@austin_perigee if you mean style overrides for the specific profile view, then no, I don’t know of any nodes to do this. You could always write a Python script to do it.
If you aren’t referring to style overrides, then you can just set the style for the parts using the CivilObject.SetStyle node in Camber.
network
This answers my question, thanks! I was referring to how the pipe or structure displays within the profile view.
