Dynamo and IronPython2.0
I am using Revit 2024 and Dynamo laste updated. Is there a way to install manually IronPython2.0 package because my Dynamo search package doesn’t work.
I have installed lot of packages manually on %AppData/Dynamo Revit/2.18/Packages%
I have put there a IronPython2 as a package it doesn’t work.
Did you install the correct version? You want the last 2.X version (I think 2.5?) not the latest version as there is a required update for Revit 2025.
Thanks for your feedback. Search packages is working I am going to update package needed.
Best regard.
