Dyanmo not reading type mark
I am creating a graph that reads the mechanical equipment in my model. Each piece of equipment has their type mark filled out (3 are VAV and 3 are AHU.) When I try to run the dynamo script it doesn’t read the type mark any idea why?
You should place a elment.Element node before the “type mark” get parameter value by name node, that way you can access to the type parameters of the element
Thank you!
Why does adding an Element.ElementType node before returns the expected result?
