Hello @all,
i got a list with horizontal surfaces sorted after their elevation.
some of them are “duplicated” because they have the same height.
Is there a way to get the “unique” surfaces only in a list ?
Kind regards
Kevin
Hello @all,
Kind regards
Kevin
Hi @kevin.scholtyssekM76 you could try get the surface centerpoint and use oootb prune duplicates for filter…or try datashapes prune.geometry…or probably use these numbers you get from sorted keys for sort
hey @sovitek,
i try to sort them by the numbers from the sorted key, but my problem is that i have less key numbers than the list numbers, so i can not match them up… or is there a way i do not know about ![]()
hi not sure, did you try prune geometry from datashapes…if you have a small sample rvt, we can take a look
hey, i did it now with unique elements and the GroupByKey Node ![]()
thanks for help ![]()
thats great, i mark your solution ![]()
