Drape polylines on surface
Hi All,
Is there a component or a way to drape polylines on a chosen surface? And that it would be scalable to multiple surfaces with different heights?
Thank you for your help in advance!
Regards,
Jonas Blazinskas
Hi @jonas.blazinskas,
The Curve.PullOntoSurface or Surface.ProjectInputOnto nodes are probably what you need.
The Curve.PullOntoSurface seems to break with openings on surface and not create separate lines.
The Surface.ProjectInputOnto works perfectly tho. Thank you!
