Hi! I am trying to create levels depending on the elevations from a model, but I am getting an error that says DisplayUnitType not defined. The script worked correctly on Revit 2021, but it does not in Revit 2022.
import sys
clr.AddReference('RevitAPI')
clr.AddReference ('RevitNodes')
#Insert elevations from the model
elevations = IN[0]
elevations.sort()
#Get the levels from the model and convert them to Dynamo elements
collector = FilteredElementCollector(doc)
levels = collector.OfCategory(BuiltInCategory.OST_Levels).ToElements()
levels = levels[1:]
#levels = UnwrapElement(levels)[1:]
#levels2= []
output = []
for l in range(len(levels)):
e = elevations[l]
e_name = str(round(e,3))
e = UnitUtils.ConvertToInternalUnits(e,DisplayUnitType.DUT_METERS)
l = levels[l]
elevation = l.get_Parameter(BuiltInParameter.LEVEL_ELEV)
name = l.get_Parameter(BuiltInParameter.DATUM_TEXT)
elevation.Set(e)
name.Set('Level '+str(e_name))
for e in elevations[len(levels):]:
output.append(e_name)
level = Level.Create(doc,e).ToDSType(False)
levels = levels[1:]
OUT = levels
