Display.ByGeometryColor node seems to be missing?
Hi!
I am new to Dynamo and I am using Dynamo 2.0.1.
I am trying to set opacity to certain solids so I can see objects inside them.
The way to go about appears to be (looking in the Dynamo Primer) to assign a color to the solid using a GeometryColor node and then output that to a DIsplay.ByGeometryColor node.
However, I can’t find the Display.ByGeometryColor node.
Any guidance would be higly appreciated.
Hi @mahir.ulker-kaustell,
The new name of the node is GeometryColor.ByGeometryColor.
Hi @Alban_de_Chasteigner,
Thank for your fast reply!
My set of nodes look like this:
Then, what am I doing wrong?
/Mahir
Sorry for the bad figure. I will try to fix it…
This is better:
It’s not possible to help you without the previews under the nodes and the error you get.
Thank you for taking time with me here!
I do not get any error messages. The proble is that regardless of what color data I give in the color palette node, the solid is shown in the default grey color.
Right click on nodes which create the preview prior to the GeometryColor.ByGeometryColor node, and disable the preview for them.
I was making an example.
Do what @jacob.small has written.
Thank you both so much. @Alban_de_Chasteigner yes, this fixes my newbie problem.
