Hi All,
I was trying dismissing a Revit dialog below.
This is my code:
# Import RevitAPI
clr.AddReference("RevitAPI")
app = uidoc.Application
def Module_Startup(sender, event):
uiapp.DialogBoxShowing += EventHandler[DialogBoxShowingEventArgs](dismiss)
def dismiss (sender, event):
t = TaskDialogShowingEventArgs
if t != null:
DialogBoxShowingEventArgs.OverrideResult(TaskDialogResult.No)
views = UnwrapElement(IN[0])
path = IN[1]
#name = IN[2]
def RemoveFirstChar(text):
return text[1:]
OUT = []
if IN[2]:
for i in views:
OUT.append(i)
Options = Autodesk.Revit.DB.NavisworksExportOptions()
Options.ConvertElementProperties=True
Options.ExportScope = NavisworksExportScope.View
Options.DivideFileIntoLevels =False
Options.Coordinates=NavisworksCoordinates.Internal
Options.ViewId = i.Id
Options.ExportLinks = True
Options.ExportRoomAsAttribute=False
Options.ExportRoomGeometry=False
Options.ExportUrls=False
doc.Export(path, RemoveFirstChar(i.Name), Options)
Module_Startup()
doc.Regenerate()
But I get an error, just calling
Module_Startup()
You’ve defined Module_Startup() with two parameters:
but then you’re calling it with no parameters:
Module_Startup()
probably you just meant to define Module_Startup() with no parameters…
Actually now that I look at it I see a few more issues…
Here is an attempt at fixing your code (I haven’t tested the dialog handler because I don’t know how to trigger that one)
import System
from System import EventHandler
# Import RevitAPI
from Autodesk.Revit.UI.Events import *
uiapp = uidoc.Application
def dismiss (sender, eventArgs):
if isinstance(eventArgs, TaskDialogShowingEventArgs):
eventArgs.OverrideResult(TaskDialogResult.No)
return
path = IN[1]
#name = IN[2]
return text[1:]
OUT = []
if IN[2]:
for i in views:
OUT.append(i)
dialogEventHandler = EventHandler[DialogBoxShowingEventArgs](dismiss)
uiapp.DialogBoxShowing += dialogEventHandler
uiapp.DialogBoxShowing -= dialogEventHandler
doc.Regenerate()
@ElCapitanDan Thanks a lot!
