Event handler problem postable command
Hello guys,
I’m struggling with event handler in dynamo. I want to supress TaskDialog from postable command.
Could you help me with this?
import System
from System import EventHandler
clr.AddReference('RevitAPI')
from Autodesk.Revit.UI import RevitCommandId
from Autodesk.Revit.UI.Events import DialogBoxShowingEventArgs
def confirm(sender, eventArgs):
	return eventArgs.OverrideResult(TaskDialogResult.Ok)
bool = IN[0]
if bool ==  True:
	CmndID = RevitCommandId.LookupCommandId('ID_PURGE_UNUSED')
	#cmdMonitor = RevitCommandEndedMonitor(uiapp)
	dialogEventHandler = EventHandler[DialogBoxShowingEventArgs](confirm)
	uiapp.DialogBoxShowing += dialogEventHandler
	uiapp.PostCommand(CmndID)
	RevitCommandId.LookupPostableCommandId
	uiapp.DialogBoxShowing -= dialogEventHandler
	error = 'Success'
	error = 'Set IN[0] to true'
#Assign your output to the OUT variable
OUT = error
@Tomasz_Puchala did you ever figure this out?
There are a few packages which use a Purge node, Orchid & Genius Loci, perhaps also have a look here?
Cheers,
Mark
