Hi
Im getting an error on the .direction() command within a python script. The error is: Vector is not callable. I
ve added a printscreen of the part of the script that gives the error. Does anyone have a suggestion where this goed wrong?
Maybe its because I`m working with class objects within Python??
If I just put a node Line.Direction after the python it does work but in the script itself it gives an error.
Thanks!
Wouter
Not callable means you can not put ()
at the end.
Only .direction
should do it.
Thats the sollution! Thanks
