I try to practice block by block. Designscript.io is the origin of Dynamo. Some blocks work and some not!
How have I to change the context. Some blocks needs lists even to work correctly!
What is the command “imperative” how can I use it… … I hope you can even open .dyn file please open in “manuel” mode!
Thank you! it is again a small (very) step forward. It seems to be that Definition are not endles like variables a,b,c,d,e,… . How much definions are disponible?
Try and go back and read the documentation you were provided, all the answers are there, but you need to understand or learn some coding syntax to use it…
