DesignScript behaviour compared to python
I stumbled upon a difference in behaviour between DesignScript and Python while trying to perform simple mathematical operations. Python yields the correct result (checked in a 3rd party software) while DesignScript produces a non-sense result. I suspect that i use Math library in a wrong way. i attach code in both languages below.
DS:
pi = 3.14;
p1 = KarmorR-Kmud-TcoreR-TfilterR;
p2 = Math.Sin(aR2*pi/180);
p12 = p1/p2;
p3 = Math.Tan(aR2*pi/180);
p4 = TarmorR/p3;
p1234 = p12-p4;
p5 = aR3-aR2;
p6 = p5 * pi/180;
p56 = Math.Sin(p6);
p123456 = p1234 * p56;
p7 = aR3*pi/180;
p8 = Math.Sin(p7);
p12345678 = p123456 / p8;
p9 = aR2*pi/180;
p10 = Math.Sin (p9);
p11 = TarmorR/p10;
p1234567891011 = p12345678 + p11;
Python:
KarmorR = IN[0]
Kmud = IN[1]
TcoreR = IN[2]
TfilterR = IN[3]
aR2 = IN[4]
TarmorR = IN[5]
aR3 = IN[6]
# Place your code below this line
pi = math.pi
p1 = KarmorR - Kmud - TcoreR - TfilterR
p2 = math.sin(aR2*pi/180);
p12 = p1/p2;
p3 = math.tan(aR2*pi/180);
p4 = TarmorR/p3;
p1234 = p12-p4;
p5 = aR3-aR2;
p6 = p5 * pi/180;
p56 = math.sin(p6);
p7 = aR3*pi/180;
p8 = math.sin(p7);
p9 = aR2*pi/180;
p10 = math.sin (p9);
p11 = TarmorR/p10;
OUT = p1234567891011
I am pretty sure I might be using syntax of DS in a wrong way, but I am unable to localize the issue myself. Anyone has suggestion where to look for a solution? Also, I couldn’t find any documentation on Math library, anyone knows if it exists in DS?
Thanks!
Please post screenshots showing the different results
Also change your first line in Design Script to
pi = Math.PI;
Here are different results. I have also changed it from 3.14 t Math.PI.
@jevhid You’ll need to convert Radians to Degrees
pi = Math.PI;
p1 = KarmorR - Kmud - TcoreR - TfilterR;
p2 = Math.Sin(Math.RadiansToDegrees(aR2*pi/180));
p12 = p1/p2;
p3 = Math.Tan(Math.RadiansToDegrees(aR2*pi/180));
p4 = TarmorR/p3;
p1234 = p12-p4;
p5 = aR3-aR2;
p6 = p5 * pi/180;
p56 = Math.Sin(Math.RadiansToDegrees(p6));
p7 = aR3*pi/180;
p8 = Math.Sin(Math.RadiansToDegrees(p7));
p9 = aR2*pi/180;
p10 = Math.Sin (Math.RadiansToDegrees(p9));
p11 = TarmorR/p10;
Thank you for the tip! I knew I was missing something :slight_smile:
