Hi guys,
I’m trying to delete the import instance as in the image but with no positive results. Has anyone of you experienced the same issue?
Any help will be greatly appreciated.
Can you share what your current approach / graph looks like?
Try Spring package delete the node.
Is there more than one instance? What you see in the Import Categories dialog may very well be a DWG link. If that’s the case you are deleting that instance of it, but not the link as a whole.
No no, it’s this instance. It is not a dwg.
