Delete Filter
Anyone know what is failing in this script to delete all the filters of a project???
Regards
A true value for the “delete?” parameter at the end.
*edit replied at same time as @Monkey_Puppet :grinning:
You need a Boolean toggle into the Delete? Field of the Delete Elements node.
Someone once taught me that if a node banner is light grey it requires more inputs to operate.
Do you know why i can delete the filters and what another custom node i can use for delete elements in case that this custom nodes does not work?
