i am looking for al tagged elements (EF) that are empty and than delete those tags.
i got my result from the list but can not delete the elements?
what am i missing here.
thx mate,
works like a charme now.
Would it be possible to upload this DYN file or give me the name of a Package? Thanks
@ericJ9ZDG it’s from genius loci not sure what version however
Funny. That is what I thought. Thanks Kai. Is that your package?
I am horrible at restringing and thought someone might share the DYN file.
Nope its by Alban_de_Chasteigner
i got independent tag for the list. how to filter by the parameter value. pls help me
I don’t have familiarity with Independent Tags, can you elaborate on the workflow? My first thought would be to retrieve the tag’s host, but I don’t know if that’s necessarily an option with Independent Tags?
I need to delete the empty tag of the plumbing fixture for a linked file. The tagged value is coming from the “Type Mark” parameter in the linked file.
I try to use Dynamo to filter only the plumbing fixture tag and try to separate between the empty tag and the tag with value.
You are not using a boolean value for your mask.
You’d need to do a check if the value is empty, and then use the bools in the filter by bool mask
As this topic was solved and your question is a different issue, you should open a new topic next time to ask your question
You can link to the old post
