I’ve tried to delete a custom node.
I’ve put it in revit package
Where is this installed? The other package are installed in C:\Users\xxx\AppData\Roaming\Dynamo\Dynamo Revit\1.0\packages, but there is’nt Revit package, so I guess it is in other path The thing is that I create a custom node and I put it in the revit package. Now I want to delete it, but I can’t find it. Thks
Well, I’ve change the package, but I still can’t delete it. How can you delete a custom node od yout nodes Tree
Thks
I thought that they were in C:\Users\xxx\AppData\Roaming\Dynamo\Dynamo Revit\1.0\definitions, but it is empty
Check here …
C:\Users<em><Username>\AppData\Roaming\Dynamo\1.0\definitions
Hi VIKRAM,
As I said in the previous post, it’s empty.
It’s an X-file
Thks anyway
You need to look at the path I suggested again
Hint: It’s not the same as the one you’ve mentioned earlier
