Default value disabled
I am learning Dynamo with DiRoots tutorial. On the 3rd lessons the exercise is to set default values from the node we have created. When going back to the work space, and I hoover close to the parameter it looks like it’s not taking to account my default value. Instead it shows “Default value: 0 (disable)” and doesn’t show any geometry.
Can someone help me to find out how to enable the default value set inside the node?
Also, the course it’s a previous version that then one I am working on, not sure if that can interfere on my results.
Hi there, did you ever find out the reason? I’m doing the same course and incurring the same problem
