Hello to all
I’m looking for the equivalent of the “Graft” option in Grass Hopper S in Dynamo.
Or help about data matching in Dynamo.
Look into list levels and lacing in the Dynamo Primer. In fact follow the entirety of the primer from end to end, as the concepts covered there will answer many of the questions you’ve had over the years. Skip nothing as it is set up to teach concepts not specific outcomes. Do each exercise and example, and ask questions in what isn’t clear.
Having used a fair bit of Grasshopper, I can attest there isn’t anything quite as intuitive as Grafting in Dynamo - usually you will have to be quite perscriptive with which levels to interact with each other. See it more like graph/branch mapping.
Below is an example of using list levels/lacing to achieve a 1 on many across multiple objects, which could be lists in themselves also:
