hello everyone!
Can you give me some ideas about this one?
I want to create a script Dynamo to Cut " between Floor and Beams".
it will create into separate parts.
You can see my idea as below pictures.
This will get you started:
You can then Get Inner Edges -> Merge Inner Lines -> Join all the Lines (PolyCurve.ByJoinedCurves) -> Surface.ByPatch -> Finally Get the area of Surface.
Good Luck!
