Curves to floor
I was trying to import a simple cad file(only rectangle curves) into Revit and extract the curves to place floor,but after I run the dyn there was no floor be created in Revit.
There is no level input:
rectangle curves to revit - but no floor be created.dyn (6.5 KB) Drawing1.dwg (38.4 KB)
Thanks for your reply!
I don’t know why the node didn’t extract the level from the dwg file.
Can you explain that to me?
Thanks again
Looks like Element.level doesn’t work with imported elements or linked. Try this:
