is it possible to make in this sublists points.by.coordinates?
because the format is x;y;z; for coordinates.
And i want a sublist that looks like that (only a example).
Bases on this forum topic: Splitting lists by value
Hi Mario,
Assuming your list is a string. Here are some of the possible ways to convert strings to points.
i dont understand what you mean
Replace “;” with “,” ?
Or try this code block def with your current list.
i tried this but nothing changed
every thime i changed it to (par,";")); after the semicolomn i get a space
i used “:” to seperate the string. But therefore i must change my format for x;y;z; to x:y:z
thank you very much
