Please HELP!
I’m trying to create Revit floor types from a mass. I have extracted the category Mass Floor, and created a series of polycurves from the surface. When I try to run the polycurves against the floor levels to create floor, Revit creates the floors then keeps running forever. Please let me know what I’m doing wrong.
Thanks in advance
massingFloors
Running manual is best for this. Element.Level is from clockwork
Thanks John, worked like a charm!
Hi Brian! I am having similar issue with Dynamo 0.9.2… it used to work fine with Dynamo 0.9.1 and previous versions. The solution that John is suggesting is nice, but I can’t figure out what changed between the versions…(same error with R2016 and R2015) CREATE REVIT FLOORS FROM MASS Thank you!!
